I'm replacing the belts, AC Power Steering and Alternator belts, I got the PS belt of easy then the AC belt is next and I got it loosened and the belt off the pulleys but I can't get the belt out of the engine bay cause there is some sort of engine mount in the middle of it or something. I have the Haynes manual and it didn't say anything about that. All it said was which bolts to loosen to loosen the pulleys and to remove the belts. I don't really want to mess around with the engine, is there any other way around that? Any help would be great.
you have to take off the bottom bolts out of the mount to get the belt off, takes like 2 minutes
(I used the old bike chain method lol just listen, ok so I slip the alt belt on first. All the way arounf the alt pullry and as much as I can on the crank pully, then I bump the starter a few times and it pushes the belt on. it works and you dont have to loosen anything.
I also heated the belts up by puting them in the oven for like 1 minute at 275*
