i second that... the b&m shifter adapter works great... not only is the neutral setting adjustable as imi noted, by setting the cable in the middle hole, the cable will be lifted higher (than the other two settings) shortening the shift even more...IMI said:i got a b&m short shifter i like it. its the only one thats adjusable. you can have it slightly away from you, closer to you or stock. i got mine closer. the only thing is it hits the consol i dont mind im going to customize the consol any ways.
