if you want to run 15-18 psi, get ready to spend some serious money on a total rebuild, turbo, and stand alone engine management. I would strongly recommend the Greddy turbo kit. It's the best bang for the buck. I got my kit for only 1490. It's less than half the price of F-max or Drag and it's very reliable. It's the best kit for a daily driven turbocharged Honda in my opinion.
good luck,
aj :)
15-18lpbs of boost on the sohc...god damn bro you have some bawlz:D if your gonna spend all that money building up the sohc to handle that much boost why not get a swap instead??? then turbo that badyboy just my .02 anyways gl bro
running that much boost on a sohc is the same as if you were running that much boost o a dohc....you still gotta buy the same parts to be safe running that high. expect to run 8lbs safely any higher then you have to worry bout rods snappin. i recommend a t3super60 turbo.
