21 - 40 of 74 Posts
mugen_honda said:
isnt the c32, an acura nsx motor and it has bout 280 hp, not jsut 200. and the itr motor is a b18c5, and itr stands for integra type r
C32A is the legend (92-95) type II touring motor, has 230 hp and is not the nsx motor, nsx has 290
swap is PROBABLY do-able if you have a V-6 platform to start with... (i.e. Accord)
3RD GEN ACCORD INFO
carotman said:
Ok, there is A LOT, and I do mean A LOT of confusion around the B20A/B18A engines available for the 3rd gen Accord
Most of the time the B20A will be confused with the B20A from the 88-91 Prelude and the B18A will confused with the 90-93 Integra B18A1. Let me tell you that these engines aren't the same despite their same numbers.
The advised eye can tell the difference between the engines but when shopping for those, it comes in handy to have another way to tell them apart other than some slight visual differences (especially over the phone or the internet)
The chart below shows you the engine code, the serial number and the car it came from.
B20A DOHC PGM-FI
Gold Valve Cover
B20A-1000001~ (Prelude BA1-1000001~)
B20A-1000001~ (Vigor CA3-1000001~)
B20A-1050001~ (Prelude BA1-1040001~)
B20A-1500001~ (Accord CA3-1000001~)
B20A-1550001~ (Accord CA3-1060001~)
B20A-1550001~ (Vigor CA3-1060001~)
Black Valve Cover
B20A-1600001~ (Accord CA3-1200001~)
B20A-1600001~ (Vigor CA3-1200001~)
B20A-1640001~ (Accord CA3-1300001~)
B20A-1640001~ (Vigor CA3-1300001~)
B18A DOHC Dual Carb
B18A-1000001~ (Accord CA2-1000001~)
B18A-1000001~ (Vigor CA2-1000001~)
B18A-1040001~ (Accord CA2-1060001~)
B18A-1050001~ (Vigor CA2-1060001~)
B18A-1050001~ (Vigor CA2-1300001~)
B18A-1080001~ (Accord CA2-1200001~)
B18A-1080001~ (Vigor CA2-1200001~)
B18A-1110001~ (Accord CA2-1300001~)
The Prelude BA4/BA5 B20A
The 88-91 Prelude (Prelude BA5 and BA4) will have their engine numbers beggining like this:
SOHC
B20A-5500001~
B20A-5550001~
B20A-5600001~
B20A-5650001~
DOHC
B20A-5000001~
B20A-5050001~
B20A-5100001~
B20A-5150001~
As you can see, they do not match the B20A serial numbers I posted above for the Accord/Vigor/BA1 Prelude
The Integra B18A
The B18A1 engine was not available in the Japanese market. The 2 engines that were available in the integra at this time were the ZC (sohc, PGM-FI 1.6 liter) and the mighty B16A.
The only way to find the B18A1 is through a USDM Integra, thich can't be confused with the B18A from the Accord since the B18A is dual Carb
Conclusion
All you need is to make sure is that the engine serial number matches those for the Accord/Vigor CA-3 or Prelude BA-1.
You can now tell the engine importer to check the number on the block without any worries of getting the wrong engine.
Here are the transmissions that will fit the JDM B20A/B18A*
Here how the chart works:
You have each auto/manual transmission numbers with their corresponding serial numbers. Then it tells you which series of engines/serial numbers and which car series/serial numbers it came from
This chart will help you to find a transmission for your Engine
Auto Transmissions:
F4-6000001~
Originaly came on:
N6-1000001~
Originaly came on:
N6-2000001~
Originaly came on:
N6-3000001~
Originaly came on:
Manual Transmissions:
A2N5-1000001~
Originaly came on:
A2N5-2000001~
Originaly came on:
E2N5-1000001~
Originaly came on:
E2N5-2000001~
Originaly came on:
B2K5-1000001~
Originaly came on:
B2K5-2000001~
Originaly came on:
F2K5-1000001~
Originaly came on:
F2K5-2000001~
Originaly came on:
Make sure you get the transmission that matches these numbers, No other transmission will bolt to your B20A/B18A.
Note that the B18A and B20A refered in this chart both come from the Accord/Vigor and BA-1 Prelude (Second Generation).
The "B20A" form the BA-4 and BA-5 Preludes had different transmission numbers and will not fit on your Accord. They are completely different Engines. See this thread for more details Where does the B20A come from?
Here are the transmission numbers you don't want.
Manual
D2K4-3000001~
D2K4-4000001~
D2K5-1000001~
D2J4-3000001~
D2J4-4000001~
Auto
K4-1000001~
PY8A-1000001~
MY8A-2000001~
When making your Purchase, stay away from these!!!!
Hope that helps
StillStockish said:
Can someone tell me the engine code for an 04 accord 4cyl
K24A# i believe...
Aran said:
This is probably a stupid n00b question (but since I'm a stupid n00b I have an excuse, eh?) but is the D17A2 engine in the '01 Civic EX the same engine in the '05 EX?
as far as i know the engines should be the same simply because they're the same generation... 96-99 = Gen 6... 00-05 = Gen 7.... i think that's accurate... if not, poo on me :cry
also, you forget the F22B6 out of the early ass oddysey's... not that they matter much... and i can't remember right now but there is the J32 series 6cyl out of the accords...
the K24A engines come in the 02+ 4cyl accords, TSX, Element, CRV and... that's it...
There's also the K20 series engines that come on the RSX and the new egg-shaped civic Si's
Yea, the H22 had three different platforms...
the H22A Gen 1 which is from the 92-96 JDM prelude Si's and had like 190hp or something
then the H22A Gen 2 which is from the 97-01 preludes and had 200hp
Then you've got the H22A-S which is from the 97-01 Prelude Type-S and has a whopping 220hp to the crank because of some kick ass camshafts...
now, in my recent voyeurs i've been researching a little on ZC's and noticed there is nothing about ZC's on this except for the single cam VTEC ZC that's really rare, and that other guy asking about ZC's and their brothers...
ZC - DOHC non-vtec. 4Cyl, 16 valve. always. at least in DOHC form. now there are like 4 different ZC's to be concerned with, much like the SR20DET motors from JDM Silvia's...
thezcr . com ZC info
http://www.**********.com/zerothread?id=1368374
(for that second link you need to enter the honda tech site)
Now, there are other weird ZC's out there but... we don't talk about them... :ninja
Accord_Type-R said:
**J35A3 - 3.5L USDM SOHC VTEC V6 Acura MDX (240hp)
It's (265hp) with 253 lbs of Torque. ;)
AND ONE MORE THING, THE CIVIC TYPE R IS NOT THE WORST LOOKING HONDA EVER BUILT.
Get that straight, you NOOB.
HONDA ENGINES
Accord_Type-R said:
I know there is another thread but it's locked.
Here is just about every single engine code Honda has built. I had some help on this one:)
**C27??- USDM 2.7L SOHC non-VTEC V6 86-89 Legend (150-160hp)
**C27??- USDM 2.7L SOHC non-VTEC V6 95-97 Accord V6 (170HP)
**C32A5- USDM 3.2L SOHC non-VTEC V6 94-95 Legend GS Sdn, 93-95 Legend Cpe (230hp)
**C32A6 - USDM 3.2L SOHC non-VTEC V6 91-95 Legend Sdn, 91-92 Legend Cpe, 96-98 3.2TL (200hp)
**C35A2- 3.5L USDM SOHC non-VTEC V6 3.5RL (215-225hp)
**J30A1 - 3.0L USDM SOHC VTEC V6 98-02 Accord V6, 97-99 3.2CL (200hp)
**J35A1 - 3.5L USDM SOHC VTEC V6 98+ Odyessy (210hp)
*F23A1- USDM 2.3LSOHC VTEC 98+ Accord EX & LX, 98-99 2.3CL (150hp)
*F23A4- USDM 2.3LSOHC ULEV VTEC 98+ Accord EX & LX (148hp)
*F23A5- USDM 2.3LSOHC 98+ Accord DX (135hp)
*G25A1- USDM 2.5L SOHC non-VTEC I-5 96-98 2.5TL (176hp)
*J25A- JDM 2.5L SOHC VTEC V6 JDM Honda Aspire/Sabre (200ps)
*K20A- JDM 2.0L DOHC i-VTEC '02+ Integra Type R (220ps)
*K20A2- 2.0L DOHC i-VTEC '02+ RSX Type S/'02+ Civic Type R (200hp)
B16A- JDM 1.6L DOHC VTEC- 89-91 Civic Si-R I/CRX Si-R, Integra RSi/XSi (160ps)
B16A- JDM 1.6L DOHC VTEC 92-95 Civic Si-R II/ 92-97 CRX DelSol SiR (170ps)
B16A ver 1 1595cc DOHC VTEC, 150ps(auto)/160ps(man)
B16A ver 2 1595cc DOHC VTEC, 155ps(auto)/170ps(man)
B16A2/3- USDM 1.6L DOHC VTEC 93-97 DelSol VTEC/99-00 Civic Si (160hp)
B16B 1595cc DOHC VTEC, 185ps
B16B- JDM 1.6L DOHC VTEC 98+ Civic Type R (185ps)
B17A1- USDM 1.7L DOHC VTEC 92-93 Integra GS-R (160hp)
B18A1- USDM 1.8L DOHC non-VTEC 90-93 Integra RS/LS/GS (90-91: 130hp / 92-93: 140hp)
B18B1- USDM 1.8L DOHC non-VTEC 94-01 Integra RS/LS/GS (140hp)
B18C .1797cc DOHC VTEC, 170ps(A/T) 180ps(M/T)
B18C- JDM 1.8L DOHC VTEC 94+ Integra SiR-G (180ps)
B18C specR 1797cc DOHC VTEC, 200ps
B18C1- USDM 1.8L DOHC VTEC 94+ Integra GS-R (170hp)
B18C5- USDM 1.8L DOHC VTEC 97+ Integra Type R- (195hp)
B18C6 EURO/UK 1.8L DOHC VTEC 96+ Integra Type R- (190ps)
B18C6/7- JDM 1.8L DOHC VTEC 96+ Integra Type R- (200ps)
B18C7 AUSTRALIAN 1.8L DOHC VTEC 96+ Integra Type R- (190ps)
B20A5- 2.0L DOHC non-VTEC 87-91 Prelude 2.0Si- (135hp)
B20B- 2.0L DOHC non-VTEC 96-98 CR-V (126hp)
B20Z- 2.0L DOHC non-VTEC 99-01 CR-V (143hp)
B21A1- 2.1L DOHC non-VTEC 90-91 Prelude Si (145hp)
C30A ver 1 2977cc V6 DOHC VTEC, 255ps(auto)/280ps(man)
C30A ver 2 2977cc V6 DOHC VTEC, 265ps(auto)/280ps(man)
C30A(?)- 3.0L DOHC VTEC V6 91-96 NSX/NSX-T (270hp)
C32A?- 3.2L DOHC VTEC V6 97+ NSX/NSX-T (290hp)
C32B 3179cc V6 DOHC VTEC, 280ps
D15B 1493cc SOHC VTEC, 130ps
D15B 3stage 1493cc SOHC 3-stage VTEC, 130ps
D15B Eco 1493cc SOHC VTEC-E, 94ps
D15B(?)- 1.5L SOHC non-VTEC '88-'95 Civic's (62-102hp)
D15Z8 1493 SOHC VTEC 114BHP (1995-2000
D16A Eco .1997cc SOHC VTEC-E, 120ps
D16A1- 1.6L DOHC 86-89 Integra (86/87 113hp, 88/89 118hp)
D16A6- 1.6L SOHC 88-91 Civic Si/ CRX Si (108hp)
D16Y5- 1.6L SOHC VTEC-E 96-00 Civic HX (115hp)
D16Y7- 1.6L SOHC non-VTEC 96+ Civic CX/DX/LX (106hp)
D16Y8- 1.6L SOHC VTEC 96+ Civic EX (127hp)
D16Z6- 1.6L SOHC VTEC 92-95 Civic EX/Si (125hp)
D17A1- 1.7L SOHC non-VTEC '01+ Civic DX/LX (115hp)
D17A2- 1.7L SOHC VTEC-E 01 Civic EX (127hp)
EV1 = 1342cc SOHC CVCC carb '84 CRX, '84-'87 Civic
EW1 = 1488cc SOHC CVCC carb '84-'87 Civic/CRX (USDM)
EW2 = 1488cc SOHC non-CVCC SOHC EFI '84-'87 Civic/CRX (CDM)
EW3 = 1488cc SOHC non-CVCC SOHC EFI '85 CRX Si (USDM)
EW4 = 1488cc SOHC non-CVCC SOHC EFI '86 Civic/CRX Si (USDM)
F18A3 1.8L SOHC non-VTEC PGM-Fi 93-98 Accord i (115hp)
F18B 1849cc SOHC VTEC, 140ps
F20A 2.0L DOHC non-vtec PGM-Fi 4G 90-93 JDM 2.0Si 150hp 137lb/ft
F20A1- JDM 2.0L DOHC non-VTEC 90-93 Accord Si (155hp)
F20A2
F20A3 EDM SOHC
F20A5 EDM SOHC
F20A6
F20A7 EDM SOHC
F20A8 EDM SOHC
F20B DOHC vtec ?.?:1CR 200hp ???lb/ft 6G 98-02 JDM SiR-T 85b/??s
F20B DOHC-1 1997cc DOHC VTEC, 180ps
F20B DOHC-2 1997cc DOHC VTEC, 200ps
F20B- J JDM 2.0L DOHC VTEC 90-93 Accord Si-R (190ps)
F20B SOHC 1997cc SOHC VTEC, 145ps(LEV)/148ps(4WD)/150ps
F20C1- 2.0L DOHC VTEC '00+ S2000 (250ps/240hp)
F20Z1 2.0L SOHC non-VTEC SOHC PGM-Fi 93-98 Accord Si, es, ies (129hp)
F20Z2 SOHC non-VTEC
F20Z3 EDM ACCORD SOHC UK BUILT 94 - 96
F22A1- USDM 2.2L non-VTEC 92-96 Prelude S/90-93 Accord LX/EX (130hp-135hp)
F22A2
F22A3 EDM SOHC
F22A4 SOHC non-vtec 130hp 142lb/ft 4G 90-91 USDM EX/SE 85b/95s
F22A6 SOHC non-vtec 140hp 142lb/ft 4G 92-93 USDM EX/SE 85b/95s
F22A7
F22A8 EDM SOHC SHUTTLE (ODDESEY)
F22A9
F22B 2156cc jdm SOHC VTEC, 145ps
F22B- USDM 2.2L SOHC VTEC 94-97 Accord EX, 97 2.2CL (145hp
F22B DOHC non-vtec 160hp 148lb/ft 4G NA-NA JDM Prelude Si 87b/??s
F22B1 SOHC vtec 145hp 147lb/ft 5G 94-97 USDM EX 85b/95s
F22B2 SOHC non-vtec 130hp 139lb/ft 5G 94-97 USDM DX/LX 85b/95s
F23A 2253cc SOHC VTEC, 158ps(4WD)/160ps
F23A1 SOHC vtec 150hp 152lb/ft 6G 98-02 USDM EX/LX 86b/87s
F23A5 SOHC non-vtec 145hp 135lb/ft 6G 98-02 USDM DX 86b/87s
H22A- JDM 2.2L DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiR S Spec. (220ps)
H22A SpecS .2156cc DOHC VTEC, 220ps
H22A ver 1 2156cc DOHC VTEC, 190ps
H22A ver 2 2156cc DOHC VTEC, 200ps
H22A1- USDM 2.2L DOHC VTEC 92-96 Prelude VTEC (190hp)
H22A4- 2.2L DOHC VTEC 97-01 Prelude VTEC/SH (97-98: 195hp / 99-01: 200hp)
H22A7 EDM 2.2L DOHC VTEC 98-02 Accord Type-R (212hp)
H22A8 EDM PRELUDE DOHC VTI MOTEGI 98- 02
H23A1- USDM 2.2L DOHC non-VTEC Prelude Si (160hp)
J32A1- 3.2L USDM SOHC VTEC V6 98+ 3.2TL/3.2CL (225hp)
J32A2- 3.2L USDM SOHC VTEC V6 00+ 3.2CL Type-S, 01 3.2TL Type-S (260hp)
K20A3- 2.0L DOHC i-VTEC '02+ RSX/'02+ Civic Si (160hp)
K24 EDM DOHC 2.4 IVTEC ACCORD 02-03 SPORT /TSX
ZC VTEC 1590cc SOHC VTEC, 130ps
IVE ADDED A FEW MORE ENGINES THAT BELONG TO THE EUROPEAN MARKET
21 - 40 of 74 Posts
