i just installed a throttle rotor in my hb, and now the gas pedal seems REALLLLLY hard to step on, almost like my brake pedal. i know the rotor is supposed to increase throttle response by shortening the rotation of the oem throttle rotor but is it supposed to make the gas pedal hard to step on?? car feels alot quicker (mentally that is haha!
Make sure you didnt snag your throttle line on anything. Also check the play you have in the line. If you have to much adjust it with the nuts close to the rotor...you should see them... you can adjust it looser or tighter depending. Sounds like you have it too tight. Did your RPMS jump higher?
