Ok my friend did an f23 swap into his 5th gen accord and everythign is hooked up right and it starts and idles fine but when he pressed the gas it would bog like crazy.
i replaced the spark plugs before we swapped it and everything seems fine..
did he get a bad motor? is it somethign internal??
Spark plugs could have moisture in them? used wrong type of gas perhaps? What octane do you use or I should say he use?
might have a slight cut in your vacum line,
does it do it when its at wide open throttle? or jsut when ur starting off
