this is my first post here - i tried the search feature and didn't come up with anything that pertained to my civic's problems. the civic is a '98 dx, 133k miles, 4 door, automatic, and has a/c. it's a two-part problem...but i'm not sure if they're related or not.
first, if i step on the brake pedal the parking lights and dash lights come on. this is with the lights turned completely off and the transmission in any position - as soon as you depress the brake pedal the front/rear marker lights, dash lights, and shifter lights illuminate. if the lights are turned on midway (to the parking light position) and then step on the brake pedal, the lights will increase in intensity slightly as well. no lights are burned out and all of the signals/hazards work properly. is something perhaps grounding out or maybe a wire crossed?
second, if i turn on the lights either to the parking or headlight position, the tail lamps (all three) seem to be illuminated almost to the point of "brake application" intensity. if you do step on the brake pedal the lights get brighter - but only slightly as they are almost fully lit at that point. i mentioned all three since the third brake light also is illuminated as soon as the lights are turned on. i don't think it's something as simple as the brake switch as they only all light up when the lights are turned on. with the lights off and stepping on the pedal they light up like they are supposed too.
i bought this civic a couple of weeks ago and have been trying to get the bugs out of it since. i bought a cd off of ebay - a .pdf manual - but it is very lacking since none of the schematics were on it and it's not designed to be traveled through like most factory service manuals. rather, it's just a bunch of scanned pages that can't be linked to one another. i can find my way around a vehicle pretty well, have most necessary tools for doing about anything in my garage, and can do pretty well with a good set of schematics. i appreciate any help you can give me on this - or at the very least maybe a link to a site that has a better manual on it.
thanks,
chris
thanks,
chris
