well, here's the 92-95 model. hope that's what you're looking for.
and the fuse is located in the dash.
for 6th gen:
1 — — 10-13 Not used
2 — — 10-13 Not used
3 (RR WIPER 10 10-2 Rear wiper, Security system (option)
RR WASHER) (Vehicles pre-wired for accessory security system)
4 R H/L HIGH BEAM 10 110-12 Right headlight, DRL control unit (Canada)
5 L H/L HIGH BEAM 10 110-12 Left headlight, DRL control unit (Canada)
6 — — 10-13 Security system (option)
7 (P/W RR-L) 20 120-2 Left rear window motor
8 (P/W RR-R) 20 120-3 Right rear window motor
9 (IGN COIL) 15 10-1 Ignition coil (‘98-‘00 models except GX)
10 (P/W AS) 20 120-1 Front passenger’s window motor
11 (P/W DR) 20 120 Driver’s window motor
12 TURN LIGHTS 7.5 10-2 Hazard warning switch
13 FUEL PUMP 15 10-2 PGM-FI main relay, SRS unit
(SRS UNIT)
14 (CRUISE CONTROL) 7.5 10-3 Stereo radio tuner (’96-’98 USA: LX, EX, and HX),
(KEYLESS) Cruise control main switch, Keyless door lock
control unit (’99-’00 models with keyless entry)
15 ALTERNATOR 7.5 10-4 ELD unit, Gauge assembly, TCM (’96-’98 CVT), PGM-FI
SP SENSOR
16 RR DEF RELAY 7.5 10-8 Rear window defogger (’96-’98 models), ABS control unit,
Power mirror switch (’99-’00 models except GX)
17 HEATER A/C 7.5 10-9 Power mirrors (’96-’98 models and all GX models),
RELAY Air delivery, Blower controls, A/C compressor
controls, Fans
18 (RUNNING LIGHT 7.5 10-8 DRL control unit (Canada)
RELAY)
19 BACK-UP LIGHTS 7.5 10-3 Back-up lights
20 (RUNNING LIGHT) 7.5 10-12 DRL control unit (Canada)
21 R H/L LOW BEAM 10 110-12 Right headlight
22 L H/L LOW BEAM 10 110-12 Left headlight
23 (SRS) 10 10-3 SRS unit
24 (P/W RELAY) 7.5 10-6 Power window relay, Moonroof
(S/R RELAY)
25 METER 7.5 10-6 Integrated control unit, Interlock system,
Gauge assembly
26 FR WIPER 20 10-7 Front wiper/washer
FR WASHER
27 CIGARETTE 10 10-7 Accessory power socket
LIGHTER
ACC SOCKET
28 RADIO CLOCK 10 (*15) 10-7 Stereo radio tuner (’96-’98 models), Audio unit (’99-’00
model)
29 — — — Not used
30 INSTRUMENT 7.5 114 Dash & console lights
LIGHTS
31 STARTER SIGNAL 7.5 21, 21-1, PGM-FI main relay, PCM/ECM, Integrated control unit
or 21-2
32 LICENSE LIGHTS 7.5 100-1 Parking lights, License plate lights, Tail lights
TAIL LIGHTS
33 (INTERLOCK UNIT) 7.5 10-12 Interlock system
