Brake swap? Will Prelude rotors/calipers fit? (relates to NSX and 92+ Legend also)
1591 Views 1 Reply 2 Participants Last post by  Accord92sir
I was reading on another fourm, that the Calipers and maybe the rotors, from an NSX will fit a Prelude. And that the 92-95 Legend uses the same 2 piston calipers as the NSX (and maybe the rotors also, i forgot).
Since the calipers will fit a Prelude (provided, running ~25mm spacers on each hub w/ an offset of ~45+)...will this also work on an Accord?
If not, then what, if any, 2 piston and larger rotors (stock Honda) will fit Accords then? (5th GN). Acura CL? TL?
Will the calipers from a '92-'95 Legend at least work on stock-size rotors with a '95 Accord?
[Saw a 600 Mercedes today, black, with black rims w/polished lip on the freeway...should've seen the beautiful looking RED calipers and large rotors in plane view through the spoke of those wheels............... I was jealous as hell.]
I'm gonna need new front pads soon anyways, and I WAS planning on painting the Caliper assembly red (the RIGHT way, removing the damn this from the rotor, and removing the f'n pads also......who the *F* paints their calipers with a BRUSH while they're still on the rotor?......anyways...though I may as well upgrade the calipers while I'm at it, that is, if I can.
Re: Brake swap? Will Prelude rotors/calipers fit? (relates to NSX and 92+ Legend also)
it should the suspension is veyr similar.
