sure it does...you're routing around it.a breather filter doesn't compromise a pcv system..
remove the hose remove the vacuum. it's pressurised via the intake hence why it is plumbed back into it. intake causes suction aka VACUUM. tell me how a ventilated filter creates a vacuumpositive crankcase vent refers to the crankcase being under vacuum. Now please explain how a breather filter would affect that?
that's completely incorrect.....remove the hose remove the vacuum. it's pressurised via the intake hence why it is plumbed back into it. intake causes suction aka VACUUM. tell me how a ventilated filter creates a vacuum
if you looked in the helms, you can see the flow direction of the pcv system. There too you will find what you just said is wrong.
I agree.....Try pinching that hose between the intake and the PCV valve. Hear a click? vacuum lose due to you preventing pressure from pulling or pushing something.
The click is the ball in the PCV DROPPING, hence vacuum sucking it TOWARDS the intake.
Helms isnt always right. Always consult MULTIPLE resources when working on a car or gathering info.
I agree.....
That has nothing to do with what I said....
a breather filter doesn't compromise the pcv system.
The vacuum comes for the the intake manifold and not the breather. So when using a breather filter, it's still possible to have positive crankcase ventilation.
thank you.A breather filter removes that hose from the system, considering that hose is the only thing that relives proper pressure build up from the highest point of the VC, it in fact DOES compromise the system. NOpressure= no pcv system pressure. You think the pcv goes from the block istelf? it doesn dude. Comes from the intake manifold and through there , there is a port that meets another port on teh block.
My advice, if you keep trying to prove to me or others that a filter doesnt compromise the system, find some proof. Ive given my thoery and I think im correct, however Im still waiting for a solid arguement upon the filters effect on the system.
Google that, dude, help us out :btu
oh really?that's completely incorrect.....
Yes, really!!!!oh really?
pcv = possitive crankcase ventilation or a pcv valve.
"PCV system
The PCV valve is only one part of the PCV system, which is essentially a variable and calibrated air leak, whereby the engine returns its crankcase combustion gases. Instead of the gases being vented to the atmosphere, gases are fed back into the intake manifold, to re-enter the combustion chamber as part of a fresh charge of air and fuel. The PCV system is not a classical "vacuum leak." All the air collected by the air cleaner (and metered by the mass air flow sensor, on a fuel injected engine) goes through the intake manifold. The PCV system just diverts a small percentage of this air via the breather to the crankcase before allowing it to be drawn back in to the intake tract again. It is an "open system" in that fresh exterior air is continuously used to flush contaminants from the crankcase and into the combustion chamber.
The system relies on the fact that, while the engine is running, the intake manifold's air pressure is always less than crankcase air pressure. The lower pressure of the intake manifold draws air towards it, pulling air from the breather through the crankcase (where it dilutes and mixes with combustion gases), through the PCV valve, and into the intake manifold.
The PCV system consists of the breather tube and the PCV valve. The breather tube connects the crankcase to a clean source of fresh air, such as the air cleaner body. Usually, clean air from the air cleaner flows in to this tube and in to the engine after passing through a screen, baffle, or other simple system to arrest a flame front, to prevent a potentially explosive atmosphere within the engine crank case from being ignited from a back-fire in to the intake manifold. The baffle, filter, or screen also traps oil mist, and keeps it inside the engine.
Once inside the engine, the air circulates around the interior of the engine, picking up and clearing away combustion byproduct gases, including a large amount of water vapor, then exits through a simple baffle, screen or mesh to trap oil droplets before being drawn out through the PCV valve, and into the intake manifold."
air is "pulled through" via the intake, hence it being a pressurized system. that's what the hose back to the intake tract does. removing the hose and putting a simple breather filter on compromises this process.
What your saying doesn't even make sense. It just proves that you don't understand how a pcv system works.A breather filter removes that hose from the system, considering that hose is the only thing that relives proper pressure build up from the highest point of the VC, it in fact DOES compromise the system. NOpressure= no pcv system pressure. You think the pcv goes from the block istelf? it doesn dude. Comes from the intake manifold and through there , there is a port that meets another port on teh block.
ok dude. you said a breather doesn't compromise a pcv system when in fact it does. it hinders the original function of the system. i like how you call it garbage only because it contradicts everything you have said.Yes, really!!!!
I'm not gonna waste my time reading something you found off the internet..... If I wanted to do that, I can do it myself.
I stated to you......
Your explanation of airflow and vacuum for the pcv system are incorrect and if you would open the helm's manual you will see your wrong.
What does that garbage you posted above have anything to do with that????
you are an idiot :lmaoYes, really!!!!
