This is my everyday driver the car runs GREAT motor was built to handle 500hp+ with no problems all you need is a bigger fuel injectors, turbo and tuning the T3/T4 should beable to put down 380WHP with a bigger turbo the skys the limit
car was built and tuned by http://www.tempestracing.com
Strut Tower Brace
Lowered 2 1/4 inches
Progress Camber Kit
Aftermarket Struts
Konig Wheels with Kumho Tires
3 Auto Meter Gauge Pods on the left piller
3 2 5/8" Gauges Tach, Boost, Oil Pressure
MSD 6A Ignition Amplifier
MSD Blaster SS Coil
Apex-I Turbo Timer
Apex-I AVC-R
Upgraded Motor Mount Inserts
Upgraded SI Radiator
MSD Plug Wires
88-91 JDM B16A
91 Integra LS Trans
Full custom 3" Exhaust from turbo back with 3" tip
3" downpipe
ACT Street/Racing Clutch 6 puck disk
Hondata ECU with boost upgrade
4 440CC RC Injectors
Spearco Intercooler
T3/T4 Turbo
HKS Blow Off Valve
Tial WasteGate
Open Dump Tube
Crower Titanium Retainers
Crower Dual Valve Springs
ARP Head Studs
JE Custom Integra Type R Pistons "made to handle boost"
JE Piston Rings
Eagle Connecting Rods
Darton Ductile Iron Sleeves
Pro Drive Oil Pump Gears
GSR Oil Pump/Housing
motor has almost 10K miles on it the chassis has 165K miles
car also comes with....
Stock DX motor/tranny both in great cond new timing belt/water pump not long before being pulled
2 extra exhaust systems "stock" and a 2.5" cat back
2 cats ones a 2.5" landspeed racing cat the other is the stock cat
2nd downpipe with closed loop dumptube
extra LS tranny
Kenwood MP3 player 4 speaker system with sub it also does XM radio Im also giving with the car a 2nd set of wheels with almost new rubbers about 1500 miles on them
as with many many more parts
In the last year I've replaced
Alternator/Alt belt
Distributor
Starter
Battery
Wheel Bearings
Axles
Clutch Master and Slave Clys
MSD Cap and OEM Acura Rotor
$12K FIRM!
Im willing to take trades + cash or a straight up trade if its a car valued in the area of 12K
I'm selling so I can get a bigger car like an A4 or IS300
my AIM is jeffie7 and my e-mail is [email protected]
if you have any questions feel free to message me I also have some videos as with more pictures
