I usually have to put in about a quart of motor oil between oil changes of 3750 miles. Does anyone else experience this? The oil loss generally correlates with how I drive my car. If I drive hard, I lose more oil, and if I don't drive hard, I lose less oil. I have all the basic bolt-ons, and 34,000 miles. I was wondering if a free-flowing exhaust system could be the culprit. Any thoughts? Much appreciated.
CS
Premium Member
What weight do you run?
It is normal, especially when running your car hard, to burn some oil. I put 4.5 quarts of Mobil 1 in on every oil change every 3000 miles. At 3000 miles my dip stick is always dead on, but it really only calls for 4.2 quarts. If your running 0 weight, I can see you burning a full quart, but if your running 5-30, a quart in 3500 miles is a bit much, unless you dog your car all day every day. Then in that case its justified.
Funny thing is I use 0w-30 (summer) and 5w-30 (winter) and I autocross from January to October and I don't burn oil. Stays at full throughout until next oil change.
i use 5w-30 Mobil 1 all year around, can u explain your decision in using 0w-30 in the summer? i'm curious
0w-30 flows better and promotes better fuel economy. According to some magazines gain some more hp from the thinner oil.
Good luck in proving that. Sounds like a load of hooey to me. I can tell u one thing for certain is that the lower viscosity oil definately finds more ways past your rings to burn off. My old partner N-Gin made the switch from 5W30 to 0W30 and his oil consumption went way up afterwards.
Honda recommeneds 5W30 all year round. I live in a region with extremes in both ranges of hot and cold and my oil consumption is Nil. I now use Mobil 1 Full Synthetic and I've never had a problem with oil consumption. Some engines do use a little more oil than others and it's normal to use 1 Qt between changes. Anymore and I would start looking around for possible reasons why.
BTW, the big claim of Synthetic oil is that it doesn't have same characteristic of a standard oil to really thicken up in cold weather. At least that is their claim, and this is supposed to make cold weather starts much easier. I can tell you with experience that my car starts the exact same at -30*C as it did before and after I switched to Synthetic Oil. However, the one thing I can't say for certain is how fast that oil pressure builds and gets the parts lubricated. I'm guess this is one advantage area as it would pump much easier on a cold start.
another difference between syn. and reg. oil is that the syn. of whatever weight oil you are using is a little thinner than the conventional oil of the same weight due to the lubricating characteristics. that's why i run mobil 1 10w30 when drag racing.
