for that motor most likley would be running a t3/t04b, i would go with the .63 a/r turbine housing, anything larger on the housing will make it spool RRREEEAAALLLLYYY slow. myself i like the turbonetics turbos, but the garrets are nice too. for compressor wheel and turbine wheel selection you really need to know what kind of power you want to make, for a quick spooler that will fill in your midrange power run a f1-54 turbine wheel and maybe a 40 or 50 trim compressor wheel. if you want more top end power instead run the next step on the tubine and either a 50 or 60 trim compressor wheel. do some reading on here about compressor maps and turbo differences before you order anything, research is KEY. good luck on your build.
