1 - 20 of 24 Posts
Crower
Bseries Vtec:
http://www.crower.com/cat/import/honda/cams/b_vtec.shtml
B18A/B:
http://www.crower.com/cat/import/honda/cams/b18ab.shtml
H22:
http://www.crower.com/cat/import/honda/cams/h22.shtml
H23:
http://www.crower.com/cat/import/honda/cams/h23.shtml
K20A2:
http://www.crower.com/cat/import/honda/cams/k20a2.shtml
D16Y8:
http://www.crower.com/cat/import/honda/cams/d16y.shtml
D16Z6:
http://www.crower.com/cat/import/honda/cams/d16z.shtml
Skunk2: For H, B, D, and K series (K series not yet released)
http://www.superhonda.com/photopost/data/519/Untitled-2_copy.jpg
Rocket Motorsports
Bseries Vtec:
http://www.kteller.com/store/product_info.php/products_id/1160
JUN III
H22
JUN Cams
Intake: 12.2mm Lift, 296 Duration
Exhaust: 11.9mm Lift, 296 Duration
*will be adding more.....if anyone else would like to add cams and specs..please feel free to post them up and i will add them to the list.
B Series Cams:Manufacturer, Intake, Exhaust
Toda Spec A 11.6 mm, duration - 250 @ 1mm 11.2mm, duration - 240 @ 1mm
Toda Spec B 12 mm,duration - 255 @ 1mm 12 mm, duration - 245 @ 1mm
Toda Spec C 12.5 mm,duration - 255 @ 1mm 12.5 mm, duration - 255 @ 1mm
Jun Type 1 10.9 mm, duration - 265.3 @ 1mm 10.0 mm, duration - 268 @ 1mm
Jun Type 2 12.0 mm, duration - 266.6 @ 1mm 10.9 mm, duration - 265.3 @ 1mm
Jun Type 3 12.0 mm, duration - 265.3 @ 1mm 11.5 mm, duration - 265.3 @ 1mm
Spoon Sports 11.53 mm, duration - 256 @ 1mm 11.13 mm, duration - 245 @ 1mm
Skunk 2 stage1 11.58 mm, duration 252 @ 1mm 10.9 mm, duration 249 @ 1mm
Skunk2 stage 2 12.3 mm, duration 266 @ 1mm 11.8 mm, duration 262 @ 1mm
Skunk2 stage 3 12.8 mm, duration 273 @ 1mm 11.5 mm, duration 273 @ 1mm
Crower 63400 10.69 mm, duration - 244 @ 1mm 9.83 mm, duration - 231 @ 1mm
Crower 63401 11.38 mm, duration - 249 @ 1mm 10.54 mm, duration - 240 @ 1mm
Crower 63401T 11.81 mm, duration - 240 @ 1mm 11.30 mm, duration - 237 @ 1mm
Crower 63402 11.84 mm, duration - 258 @ 1mm 11.84 mm, duration - 251 @ 1mm
Crower 63402A 11.84 mm, duration - 246 @ 1mm 11.81 mm, duration - 239 @ 1mm
Crower 63403 12.04 mm, duration - 267 @ 1mm 11.84 mm, duration - 257 @ 1mm
Integra Type R 11.5 mm, duration - 240 @ 1mm 10.5 mm, duration - 235 @ 1mm
Civic Type R 11.5mm, duration - 243 @ 1mm 10.5 mm, duration - 235 @ 1mm
and thats all u need to know boys :tu
98vtec said:
hmm, i'll check into that tomorrow and see what i can find.
having a All Motor Forum is going to help me out a ton w/
information/knowledge and research! I will do some F series research tomm as
well and post up what I find. im so glad us n/a fans have a place to unite!!
yay!
b18b specs are similar for the b20a5... the 3rd gen prelude motor...
colt and web make cams for the b20/21 as well...
gotta have love for the F series.... torque!!!
Guys,
Is there any way of knowing the opening - closing timing of the camshafts, maximum lift, etc?
Stock ones I know, but not the aftermarket ones.
Thanks,
B.
Discussion Starter #12
ballyvti said:
Guys,
Thanks,
B.
timing would be on the cam spec card.
The maximum lift as in what the head will allow?
The good thing in buying stuff second-hand is that bits and pieces simply go missing.
Like spec sheets :)
As for max lift, I mean the max lift of the cam.
You know my problem with the dipping car.
I just obtained an engine modeling SW, and I need this data for it.
Of course I found the OEM cam data, but not the ones for Skunk2....
B.
Discussion Starter #14
Like spec sheets :)
B.
whats the engine code?
Discussion Starter #16
Discussion Starter #18
ballyvti said:
Thanks, but this is only basic data.
Where does the intake open and close? What about exhaust?
Or does this cam open and close at the same position as the OEM cams?
Like 10 degrees BTDC etc?
B.
i dont know on a bseries...i'm sure one of the bseries guys will chime in to help yuh.
you know when K series prices for skunk2 will be post or do you have to call.
1 - 20 of 24 Posts
