Well if anyone has read my all motor thread they'd have some info on crower. I went crower titanium retainers, dual springs, ss steel valves, and stage 2's with stock idle lobe (which I recomend, don't fuck with the sensors. The duration of these is way above stock and my ecu doesn't like it. May be bad fuel pressure but I've got map code, and fuel communication code and knock sensor code. It bogs like hell at 1500 rpm (have done all kinds of cam gear adjustments). Above 2500 rpms it's crazy. May be due to lighter forged pistons and rods and higher compression but at 6300 rpms it's wicked sounding and the pull is crazy. Mind you I've got all kinds of cels so my timing is retarding. Can't even imagine how it will be when the cels get taken care of, just to damn cold in ohio to worry about it, the car just sits.
All I've got to say is my 5 th gen pulled to 140 SO much faster it's crazy and it's untuned
With ems I think stage 2's are plenty sufficient. I might sell mine eventually because my new head can accept a cam with a .515 lift. I recomend port and polish work also with these cams at least a stage 2 and get the bowl area done for sure that's where most of your improvements will take place. Basically what I'm trying to say is that my build feels basically as strong as the zex 75 shot did but minus some torque actually a lot but I can go that route too.
Just some experiences to help pursade people to crower. I think the products are awesome it's retards that install the shit wrong.
I mean technically you should have your cam journals at least line bored if you're dropping new cams in. That's why peoples cams break because the clearances are all fucked up because they drop the shit in beat on heads![/QUOTE]
thank you, you have made me smile... your the first person ive heard say that in a long time... its 100% true lol, if your gonna do all of that work, take the time to get your shit fixed right, doesnt cost much either, lazy asses lol
