1 - 11 of 11 Posts
I'm the DIY tuner type, and i just want some opinions on purchasing a Camber Alignment Gauge. Since i'm purchasing the Tein SS Coilover.
I have done one too many Alignments and it cost more to do an alignment after installing aftermarket camber bolts/ball joints.
Also has anyone have any bad experience with these Guages?
Heres a link for a site that sells the gauge.
http://www.longacreracing.com/catalog/item.asp?id=132&catid=5
hell, why not just make a jig to attach a few mini bubble levels to the rotor and then align it with them?
Go to your local hobby store and buy a camber alignment gauge for an rc car. It'll cost about $9.95 . Just line a 2x4 up against the wheel and use the rc car guage. Here is a pic of one :
yeah, i know that it is ghetto, but doesn't seem like you need fancy guages to just read an angle.
Discussion Starter · #4 ·
This doesn't sound like a bad Idea, but have you tried this yourself?
Also which is a better camber item to purchase Ball Joint, or those Bolt kits that cost too much for a screw and some washers.
I like the bolt kits or Upright mount kits.
the ball joint kits change the geometry a little and can hit the upper mount area.......
It won't be super accurate, but an angle is an angle. Only issue is that you would have to do it on level ground.
I recently just put my camber kit on, and before taking it to the shop to get it aligned, i "ghetto" aligned it using a bubble level. To do this you have to not only elevate the car symmetrically, but also jack up the suspension to the point of typical ride height. Try to find a nice flat surface for your car too.
I simply removed the tire and used the disc brake rotors as a flat surface for the level. It seemed to work pretty well, as my car didnt pull in any direction afterwards.
I wouldnt recommend ghetto aligning the front end of your car, you are just asking for too many weird handling characteristics... but the back really isnt a big deal. Either way it is useful before a real alignment.
As far as alignment pricing goes, i paid 48 dollars and i have a front and rear ingalls kit installed. Its just some simple bolts; mechanics that do alignments are used to encountering camber kits.... they shouldnt charge any more than usual.
-p
thats old style alignment gauge, man those things are ******, i like doing them on the rack 100 times more then doing it with a gauge
there are a couple of shops in my town that offer a lifetime alignment deal, you pay for the equivalent of 3 alignments and then they'll align your car for as long as you own it. May be someone offers the same dean in your area.
just take it to an alignment shop.....so you can have precise camber adjustment for whatever application you want.....
Ball joints suck ass. My controll hits my fender wall which in turns doesnt let me lower it all the way. So i have to keep them on the minimall seting so i dont hit the fender wall
1 - 11 of 11 Posts
