camber kit...
2475 Views 27 Replies 15 Participants Last post by  4BangingCord
what kit should i get with my h&r race / koni yellow setup??? i really don't care about the top of the line , i just want sumthing that will do the job and do it cheap. peace!
1 - 20 of 28 Posts
ingalls
get the ingalls kit. they are very reasonably priced and they are very, very good.
what is the cheapest place i can find em'... i checked groupbuycenter.com, and they want almost 300 for a kit, thats rediculous!!!
kit...........
is that a complete kit for all 4 tires? I just did a quary on yahoo typed in ingall camber kits and I found a store ( forgot sorry ) that sold my camber kit for all four at 300 bucks and that includes shipping. I have a 93 accord!
how bad would you need a camber correction kit if you have H&R race springs with stock shocks? how long can i wait without the camber kit before my tires are fucked?
ingall kits have clearence problems...thats all I will say.
skunk2 make a camber kit, i think it costs US$190 per pair of adjustable upper A arms. check out www.jdmhondaparts.com or www.skunk2.com .Technica Sport/Vision also make some,but they cost about 72000 yen, about AUS$1000! thats still US$500 with your good exchange rate.
what about specialty products co. camber kits? how are they? anyone know where to get them?
Any kit like Ingalls that tries to adjust for over 2 or 3 degrees of negative camber is going to run into clearance problems.
sorry dumb question...but what exactly is meant when you say clearance problems? like going over speedbumps?
Would you mind going into a little detail with this. I mean you gave this negative thought with nothing to back it up :confused:
I am curious because I am thinking about getting ingalls for up front at least.
Thansk
I'm going to pick up my spc camber kit this week. I got it from a shop in denver for 350 with front, rear, and lower control arms.
I let you guys know how the kits is.
mister prelude tried putting ingalls 3556 on his neuspeed race lowered prelude. He had clearence issues with the actual camber kit itself rubbing the tire I believe. he had to shave the camber kit down to make it fit. his brother had the same problem with his accord.
is there any easy way to fix my bad camber? lowering a car seems like a bitch and a half...:(
damn... why is shit soo expensive??? can't i just pick up a cheap one at AutoZone, or Napa or sumthin???
I agree lowering is expensive...........
damn lowering is expensive and to my opinin after going through with this it's almost not worth it for the better handling. Damn I bought tokico illumina with springs thats 538 bucks shipped, getting someone to put them and alignment is 345 bucks, then camber kits all around is going to cost 300 bucks and then getting someon to install them maybe 300 bucks also. This is almost not worth it. Then we have clearence problems with our innder fenders rubbing. Damn I'm lost on what to get for camber kits. I was gonna get ingalls, but they have correction problems past -2.2 for correction. What camber kits can I get to correct my -2.2 front right side withough clearence problems any suggestions anyone?
The clearance issue is with the control arm and the lower fender. The ingalls kit replaces the non adjustable anchors on the control arm with adjustable ones. If you have extremely negative camber then you may encounter contact when you adjust the anchors causing the control arm to come out further from the inside wheel well. Adjusting beyond 2 degrees may require to alter the inner fender lining slightly for control arm clearance. Basically, unless you have an extreme drop, you shouldn't have problems with the clearance issue.
okay I am that mister prelude that lOOkatme refers to. The problem with the 3558 kit is that the camber kit will hit the body frame when you are going at a decent speed, over a bump. It's happening to me right now, but I can't do anything until my Tein coil overs come in. You'll have to shave the corner that is hitting the body frame down. The same thing happened with my brother's accord, with the kit #3557. You can see where the camber kit hits the body frame. When I install the Teins, I'll try and take pictures of it. Bottom line, the #3558 kit does offer a lot of adjustment (1 3/4"-4 1/4") but it's going to have clearance problems.
what kit do you recommend buying mister prelude??
also is this a problem only for the front??
1 - 20 of 28 Posts
