Hej
I m wondring if it s posible to use cams from D16Z6 engine,to D15Z6 vtec-E engine-Europian models.
Is it two diferent systems of Vtec in those engines.
Reggards
Bob
You can do it both are d-series motors. VTEC works off oil pressure all the lost motion assemebly , rockers , cams should be the same maybe a little different profile. Throw them in there and see what happens make sure you look up all the proper torque specs.
You obviously didn't look at the picture did you?
