hobie237 said:get a rebuild kit... jc whitney has them for about $400 and they include everything... gaskets, seals, valves, whatever...
you could probly save some money and just grind the valves... but for a good rebuild you gotta bore out the carbon deposits in the cylenders... which requires a mill....
Well how much you want to spend? You can do many different things. Really depends on your budget. Do you want aftermarket rods, crank, pistons? Want to keep your stock components?Hondalos11 said:im keeping it N/A! with enough power to have fun myself.
boring increases displacement. not compression.hobie237 said:with na you should be able to stay with stock rods/pistons, but if its bored for more compression i would go aftermarket, as i would go aftermarket with turbo...
the stock rods are pretty good, but i would not trust them for turbo or high compression...
Snoopy said:boring increases displacement. not compression.
