SO I was working on my Crx with a 96 Integra GSR Engine. I rewired the MSD Ignition wires cause they were a mess and Tried to start it up and it didnt start. I was Cranking and cranking Untill the Battery Died. So I took a look at the Msd Wiring And FIgured out I forgot to Hook up a wire. SO I hooked it up started Perfect. So I turned it off and Started it back up an hour later. I noticed the Exhaust HAd white smoke COming out of it. Not a lot But a little Like a morning cold start up. Then I popped the Hood and noticed White smoke Coming out the breather. So I turned off the car and Pulled the Valve Cover Cap Off and It had white smoke coming from there to. I smelled the Cap and It smelled Like Gas. Hmm Do you Think I flooded the Engine with gas??? So Just the cap Smelled like gas. When I pulled the dip stick out it Didnt smell like gas. :bash
