21 - 30 of 30 Posts
Discussion Starter #22
all right cool i am new to honda stuff so i am just goin buy what i have herd and been told and here in australia not many poeple go hard on hondas its all skylines and silvias and holdens so yeah
D16Y4 is an Australia Build.
Yes I do have that engine, again I am from Australia, and I have got my parts of the list already except a few stuff but later will get to it.
Boost Junkie
Hello, I'm new as well..I have a d16y7 4 door LX. I just wanted to turbo it at first just to get familiar with the parts and how it works. Then once i run it long enough and learn a lot more i would start working on making it even better. 150hp is plenty for right now. So what i have read is it would be fine to run a t3/t4 on stock internals. Which is what i am thinking about doing. Although my engine has 125,000 miles on it so i might just want to rebuild and reseal the engine anyways just for longevity purposes:p.
don't thread jack, its not nice :ninja
D16Y4 Turbo
Now I've seen D16Y4 with Turbo done up to 358.9 HP believe that? A lots of modification though. But if you are running stock? Like ME!?! You can here's the list:
D16 Manifold with hole for Wastegate
T3/T4 Turbo
T3/T4 Downpipe
.38 Tial External Wastegate (Keep your engine safe)
Blow of Valves (Keep your Engine safe)
OIL Feed + Return
PIGGYBACK ECU (such as APEXI ASFC) you won't need a new ECU.
Intercooler and Pipes
Those are the main point to get your Turbo running safe with External Wastegate you will run stock 6 to 7 PSI. But if you are going to boost, I suggest you de-compression your engine (meaning upgrading your Internal engine) which means more cash out from your pocket!
I just installed mine in with AC/Compressor still attached :clappy I fired up a few times already its good safe, but when you do it yourself make sure you do it PROPERLY!
Boost Junkie
D16Y4 Turbo
T3/T4 Turbo
T3/T4 Downpipe
OIL Feed + Return
Can you make me a list of what i need to make my d16 turbo i want around 400 hp
21 - 30 of 30 Posts
