were does axxis fall into that line u got ?kommon_sense said:stock rotors are just as good as any other rotor and rotors play a very small role in braking. So if you want new pads go for it. However I would recommend that you get your rotors turned/machined before putting the new pads on. You do this because rotors end up with bits and pieces of brake pad embedded in them (this is a good thing). So if you change to a completely different pad, then you want to clean that up as the pad compounds may not be compatible with one another.
carbotech bobcat > AEM > stock pads![]()
This is true the axxis were racing pads and did not perform well at all cold.. but warmed up they were the best stopping pads i have ever bought.. too bad they lasted less then a year.UltraMagneticAL said:depends if you get the metallic ones or the regular stuff (does axxis make OEM replacement pads?). metallic pads are made for racing and suck when they're not warmed up. the regular stuff, like what your OEMs are, work well on the street but suck when the temps get high from braking going into the corners. there is also carbon-metallic stuff that works well for light track duty and street use.
