1 - 8 of 8 Posts
My 94 Gsr's tranny will not ingage when trying to downshift to second gear. After I have driven around for a half hour or so.
I can go from 1st to 2nd, 3rd, 4th etc but when downshifting from 3rd to 2nd it will not go in- until i have driven for a good while..
Is it just when it is cold, or does it happen everytime you start it up during the day?
I know that Honda 5-spd transmissions are notchy when they are cold. But if you can't downshift specifically down into 2nd gear, then I would think you might have syncro problems with 2nd gear.
What kind of tranny fluid are you currently using? If you're using synthetic transmission fluid, change it to Honda.
Correct me if I'm wrong, but doesn't double-clutching do the same thing as rev-matching in this case? Just gets the synchros spinning at the same speed, right?
1 - 8 of 8 Posts
