1 - 20 of 22 Posts
i have a 92 cx with a 95 d16z6 w/ greddy kit...car would not rev past 3500..its like im hitting redline...heres my list of wat i have...bov..side mount ic..boost gauge..air/fuel gauge..turbo timer...everything on the engine is stock..also using 95 p28 ecu..check engine light is on..it says fuel system is not running properly..too lean or too rich....also getting map sensor code...i am also running check vavles..might not be enough but still wouldnt cause the car to not rev past 3500....also i am still using the single wire o2 sensor ...
i think you might be a little too lean... maybe you need to supply that engine with a little more gas...
Discussion Starter · #5 ·
yes it read lean but i dont know how to correct that..i dont even know if its right since i was told that i had to change my o2 sensor out to a 4 wire one...but yes it read lean...how do i adjust fuel if everything is stock??is that possible??
You're running too lean or.....
either you're running lean or you don't have enough check valves, and your map sensor is picking up boost. Do you have a A/f ratio gauge??? If not then you really should invest your money and get one. But i think you're running too lean. My friend uses like 6 check valves, so you might have to put more. later
Discussion Starter · #8 ·
a fuel problem ...would that be the fuel pump??..injectors??..all maybe??how do i come about checking these items??...is there any other fuel source that i missed??all i could think of if injectors and pump when mentioning fuel
for sure Pump.. injectors you just need to check to make sure they are not clogged and as far as the FPR check the psi setting on that and let me know what its set at... and check the FMU that you have setup.. b/c more often 9 out of 10 times the FMU is not hooked up correctly or its backwards..
Discussion Starter · #10 ·
ummmnn...everything is stock....stock pump..stock fpr...stock injectors...no fmu yet.....i was told ill be alright for a lil while without fmu(in the process of finding a decnt one)...i guess theres the prob not enough fuel...but isnt there ppl out there that is running turbo without any of those mods??...with an inline pump would it be just an ad on or replacement deal??
fmu is a fuel management unit
u must a some kind of fuel enrichment
if you are boosting the default boost setting of 5 lbs, you will still bog at 3500 rpms, your stock fuel system is not providing enough fuel for your the extra power that is extracted from your motor. Remember, 5 lbs is equilvalent to about 40 to 50 hp, so how do you expect your setup to be running properly without fuel enrichment. Get a boost dependent FPR or something, and as of now if you're flooring your car, you'll killing your motor when it bogs like that.
no need for fuel pump
im boosting 8 lbs with stock fuel pump and stock injectors, just using blue box for fuel enrichment
1 - 20 of 22 Posts
