When the car is off, unscrew the gas cap to relieve pressure, and put it back on. Get into car, and turn the key til the dash lights up DONT start the car. What you want to hear is a whirring noise, then a click, then it goes quiet. If it does that, your fuel pump is working fine.
Next, go under the hood, unplug all your spark plug wires, keep them in order, or write it down and maybe stick some tape on them and write there location.
Take off the disty cap via 4 screws, and pull straight towards the passeneger fender. Look at it underneath. Does it look burned or warped at all? If it is even a little dirty, you have your problem right there. cap and rotor is 10 or 20 bucks
the rotor slips off once you remove a screw on the shaft. be careful not to strip it, some cap and rotor kits have a screw, some dont. Depends on the packaging worker that day if he was lazy or not.
keep us updated on your progress, we're here to help :btu
