fiber images makes the BEST CF hood on the market next to spoon sports. the fitment is GREAT, the quality of the weave is AMAZING, and it looks downright gorgeous!!!
i have had mine since july and i am VERY happy with it.......NO problems whatsoever. i dont even have hood pins on it. the fiber images latch is VERY strong. i've driven over 100mph for long periods of time hundreds of times with this hood, and NEVER even thought twice about it flying up.
.......oh, and if you dont believe me on the fitment issue. just take a look at this pic WITH the hood on. 10 bucks says you would have thought it was the OEM hood if i hadnt told you otherwise
PS: one thing though. if you are going to get a CF hood it is IMPERITIVE!! to get it put on by a professional body shop. when my body shop first put it on, it didnt line up perfectly, they needed to work with it a little. also, the MAIN reason is that the rubber lip at the end of your stock hood, cannot be reused on a CF hood, at least there are no holes to mount it. but i had my body shop drill small holes (VERY risky, the hood was very thin) and were able to mount it with 4 small plastic screws and some epoxy. without that rubber peice there will be a 1/2" gap between the hood and your grill/headlights.......it looks REDICULOUS!!! i know, because after the body shop put the hood on, i went to check it out and nearly vomited. that's when i demanded they re-use the rubber peice by any means nessesary. so trust me, it's worth the extra $100-150 to get it professionally done. you can tell the difference in quality of installation. as you can see from my picture, it looks like my car came with that hood
