would I benefit from a cat w/alarget diameter inlet/outlet
I have a dc 4-1 header and a RSR Ex-mag exhaust (97 Ls)
should I buy a larger diameter cat? ir should i go for a direct fit?
what are reputable retaliers online that carry carsound cats?
thanks for the help guys.
What the outlet size on the header and what is the inlet on the exhaust. If yo have a 2.25 on the header you can go with the same on the inlet of the cat or you can go up to 2.50. Basically you would have a stepped design.
Like this...
Header (2.25outlet)--Cat (2.25inlet/2.50outlet)---Exhaust (2.50inlet)
This will not harm the motor as far as "choking" it from back pressure build-up
