CEL Code 36?
1308 Views 6 Replies 3 Participants Last post by  JDMFreak
92, Si VTEC
What does CEL Code 36 mean?
Can't find info on it anywhere.
Tanx.
are you sure it not code 3 and 6??
or
???which one???
thx to ECU CODES *all of them*
-code 3 = MAP Sensor (Manifold Absolute Pressure)
defective circuit or unplugged / defective sensor
running rich or smell gas .... that would be it
-code 6 = ECT Sensor (Engine Coolant Temperature)
from this chart there is no code 36 but i could be wrong
JDMFreak said:
or
???which one???
It's defo this one:
You're throwing 2 codes then...3 & 6
Code 3: Manifold Absolute Pressure Singnal
-Open or short in MAP sensor
-ECU/ECM
Code 6: Engine Coolant Temp. Circuit
-Open or short in TP sensor
-ECT sensor
-ECU/ECM
Have you tried reseting your ECU yet? Do that, and see if you throw those codes again.
Ah I see! Thank you very much for your help! I'll try a reset of the ECU later.
This happened after I installed my friends non-4WS ECU into my car and he tried mine in his (trying to see if the ECU was the cause of my hesitation) My sunfoof doesn't open anymore, but I guess that I musta pinched or loosened a wire when I was putting the ECU 'fortress' back together!!
Thanks again!
