center console
1000 Views 10 Replies 7 Participants Last post by  dwnthehatch
how the hell do i get the center console out the shiet wit the radio n shiet in it i cant seem to get it out =D
1 - 11 of 11 Posts
You have to unscrew the screws that hold the bracket in. You will need to take out the bottom under the steering wheel, and under the center console. It will take a while but just need to take off the bottom pieces to get to more screws.
roll up to jdmfan, there is something about it in the technical section.
If i were you i wouldn't take it out, the other day i took out the temperature console and it was the biggest bitch in the world.
DO YOU NEED THE WHOLE CONSOLE OUT OR JUST THE COVER WHERE THE STEREO AND HEATER/AC CONTROLS ARE?
if you want to take the part out where the radio is, you have to start by taking the glove box off, then the part underneath your steering wheel. more screws will appear, and you take them off until you get to the center. i've taken my radio out a whole bunch of times, and thats how you get to that part.
you dont need to take all of that stuff off the cover is held on by clips it will pop off if you slide a flat head screw driver behind it and turn it slowly do each side and the cover will pop off
The whole radio-a/c are all screwed to the one piece
sure it all in one piece ? i just want the cover out
It's all screwed in together There are four screws under the radio that haols the whole thing in along with the clips.
1 - 11 of 11 Posts
