Ok on the center dash counsul or however you spell it, on a 9 accord i got the 2 screw out of the bottom of the cd player and it seems to still be stuck. I just want to know if there is any more screws that i just cant see, or is th rest just held in by clips that i just need to give a good tug or 2 to get off. I need to get the serial number off the back of the cd player because its locked me out in case your wondering, your help is greatly appreciated.
What model car do you have? I assume your talking about the Civic in your sig?
Anyways there is some times a screw behind the clock which you need a credit card or something thin to remove the clock to gain access to the screw.
There is a screw behind the clock. You can just pull the clock out if carefully
dislodge it a bit with a screw driver.
The rest are clips, fo oyu have to still pull a little on it to get it off.
Yes in a 99' Accord there is a screw behind the clock. Work from the bottom up when you try to remove your trim. I found that it is much easier to work from the bottom up.
