How do you change the air filter on a 2003 Honda Element? need help..tnx..
______________
hondaneon46165
there are 6 screws holding it on and u have to unclip the 2 throttle lines and unplug the large vacuum line. make sure to plug the large vacuum line back in when replacing the cover. ps i also recommend a k&n air filter or some other high flow filter. i gained 1-2 mpg w/my k&n
Locate the air cleaner box..It is on Driver's side engine compartment..Remove screws from air cleaner box..You will find this screws only in 2003-06 Honda Elements..Pull the air cleaner box cover where you can see sir filter..Lift it out and just insert the new one..
