Never done one before, but if its just rotor ...its not hard. If i recall, honda's use 14mm bolts to hold the caliper brackets on. Remove those two bolts and pull the brakes off. Should come right off. Then remove the rotor its easy. Basically you'll need , a 3/8 ratchet, preferbly a long handle one, 14mm, 12 mm sockets. Thats about it. Thats about all i used on my hatch. Oh, 10 mm too to get the cover plate off. It purdy straight forward, just dont forget to tighten things up.
