Just a little FWI
i belive its 92 - 96 prelude vtec brakes that came in 4-lug combination
they are 11 inch rotors + the biggest 1 piston caliper that honda ever made...
its a DIRECT BOLT ON for your accord...
you MIGHT have to use an angle grinder, i know u do on an integra
anyway, i think its a really nice mod for anyone whos sirious about stopping power....
FlySly54... im talking to you
Super Ban-Finger Mod
uhm...better tires work much better...the only reason to get a bigger rotor is if you're having cooling issues.
yeah, pads and tires decrease braking distance. fluid is for high temp situations, as are lines...but lines also increase the ability for brake pedal modulation. bigger rotors help in heat dissipation. calipers are for clamping force....but only if you have LOTS of power and have the tires w/ enough grip to match that kind of clamping force so you don't lock up.
DIRECT BOLT IN for 5th gen accords ONLY I'm assuming right? 4th Gens have hub over rotor design, but can be converted using Acura CL hubs. To use the prelude calipers, I believe you have to go out and get 23T brackets
