Check engine light
1125 Views 7 Replies 4 Participants Last post by  40_Below
I just got a b16a2 swap and I have the check engine light on. The car runs really good yet the light is on. I was told by my mechanic that it is due to a sensor that is out, since there is no input on my stock intake manifold. Does anyone know if this is true and how can I solve it? Also there are a whole buncho of new cables and connections on my engine that weren't there before, is this normal?
1 - 8 of 8 Posts
I have no clue
I have no clue man, I know nothing about ECU's or swaps
jump the service plug located under the passenger side... and turn ignition to on and count the pulsing engine light... long ones and short ones
"jump the service plug located under the passenger side... and turn ignition to on and count the pulsing engine light... long ones and short ones"
Thanks for answering dude, but that sound like chinese to me. I don't know [email protected]!$%t about engines. Thanks anyway
use the link I posted to check the CEL codes...post up and tell me what code it's throwing and I'll tell you what's wrong with it.
Unplug your red battery cable for about 15 minutes.
If that doesn't work, go back to the mechanic or whoever put it in... If you got the engine, you should have gotten the ECU that came with it, I beleive.
1 - 8 of 8 Posts
