OK guys, I put in a new ACT clutch set-up like a month ago, due to the fact as the last one started slipping because I didn't break it in. It's a xtreme pressure plate with street disc and resurfaced streetlite flywheel. Also put in a new tokico clutch and slave cylinder.
Now I remember where it used to grab when I put the orginal ACT set-up in, somewhere near the middle. Before I swapped the old set-up out it started grabbing high. Now it's still grabbing pretty high up, like right after I push the pedal in. I don't really like it and I was just wondering if I could fix it somehow? I thought the new set-up would fix it.
My stock clutch grabs just as high. I agree that it is really annoying expecially when you shift into a gear or downshift and think the clutch is all the way out but that last inch is missing and u get slammed into the seat.
I was hoping actually that an aftermarket clutch would rid me of this problem but according to you it might not. We'll see what people say...
Discussion Starter · #6 ·
Type_SH RaCer said:
Did you change out the TOB?
Yea, brand new throwout bearing.
