on my girlfriend's eclipse, her clutch has no tension and cannot get into gear. we checked the master cylinder and there was no fluid, so we bought brake fluid and put it in. we pumped the clutch, but the fluid was not going down, we checked for leaks in the master and slave cylinders, but we couldn't find any leaks. what could be wrong?
since you ran totally out of fluid simply adding fluid will not fix it, you must bleed the clutch line for it to work again. also i would try to find where it might be leaking. slave cylinder, master cylinder, and the line, also check the inside around where the clutch rod goes through the firewall. see how that works for you. let me know if that fixs it.
:D i got the tension back in the clutch pedal...come to find out the damn master cylinder be leaking through the firewall:mad: ....now i need to change my master cylinder....
thanx for the info bro
