Whats up yall, I installed my new Exedy organic race clutch in my 91 teg last night and it doesnt work. I had my flywheel resurfaced, when I bolted the pressure plate and disc up, the splines/springs on the pressure plate are all flat instead of pointed out a little, almost like the disc was too thick or the pressure plate was too tight. I have my cable adjusted as tight as it can go and I cant disengage the clutch. There is way too much play in the clutch shift arm because the splines are all laying flat, and because of that you can only push the splines in a little more before the hit the disc. Sorry if this isnt written the best, I was up until 6am working on this ****, I hope someone can help me out, because I really need it. BTW Ive done clutches before, never a cable tranny though. TIA
