asianpride559 said:
oh yea. i could still drive normally but only thing is that i cant race with nitrous. well will see if it is damaged next sunday. but wat sucks is we putting clutch in on a sun and sunday is the only day we could put it in and no machine shop is open on sunday. it just barely started slipping. first time
Okay, enough fun and games for now...
If that's the case then, your best bet would be to either hold off on the install until you can get a day to take it in where you could get your flywheel resurfaced at the same time, otherwise you will be wasting your money and a new clutch.
Your other options are to...hold off on the install for another week or two and see if you can order a lightened flywheel online or from a shop. I'll throw this one out there too because some people do have this luxury...go by a junk yard and yank a flywheel from a fucked up car and get that thing resurfaced and use it in your car. Like I said on the last one, some people have the luxury to do it.
Anyways, if your clutch is slippin bad while you are on the juice, even if you only spray in second gear, then I would highly recommend that you baby it until you can get a new clutch and your flywheel resurfaced. If you continue trying to race it, if its in that bad of a condition, you could glaze the flywheel to the point where resurfacing will not even be an option.
Ignore the post if you choose cuz, but I'm actually trying to give you serious advice on this one.
