I Finally got my 96 Si and ran perfect for the 1st 2 wks. On my way to work i got 2 the stop sign i tired to put it in 1st it wouldnt go so i cut it off and crunk it in 1st and got it home. I ended up bleedin the clutch. And now every time i take off the clutch make a scrubbing noise. Do anyone know whats wrong it?
Before any of this stuff started to happen, every time i goto 5th gear it grinds a little. Any suggestions in what to do.
How do i adjust the clutch pedal position, on a 96 Si?
are there any visible leaks from the master or slave cylinders?
do you hear any grinding at idle but goes away when you step on the clutch pedad?
Only when i take off it makes that noise. I havent no leaks, but the slave cylinder looks old and rusty and the rest of the motor and trans looks clean.
