I put a cm stage 3 and alum flywheel on my 2000 base. at first i didnt have problems. but recently my slave cylinder has been making noise(squeeking). a couple of mechanics said it's because i used the throwout bearing that came with the clutch kit instead of using the stock honda throwout bearing. has anybody else done the same thing when changing their clutch out. I was wondering if there is an aftermarket slave cylinder i could get and where can i find one. If i don't put the honda throwout bearing back on will it screw anything up?
