Its really hard to even understand what your asking. Not to mention the fact you have a ITR wing is totally irelevent.
Let give this a try. It sounds like you recently had a new clutch put in and now when you put it in gear it doesnt go. Well, does it actually go into gear or does it just not go when you let off the clutch in gear? Maybe the clutch wanst proken in properly and its fried. Or maybe you a tranny related problem. If your axles broke you can put your car in gear and it wont go anywhere. Check your axles to see if they have any play.
You're the ony one who has axle problems
j.k :aww
But it really doesn't sound like an axle problem.
Who changed the clutch? Was it a qualified mechanic, a friend, or some guy? Does it go into gear when the engine is off? Describe the problem with more detail.
