1 - 12 of 12 Posts
OK guys, I am geting really irritated with with this check engine light. I have gone through 4 different IAC's and still my light is on. What is deal?
Discussion Starter #5
I have gone through the wiring -- TWICE.
I dont believe its the ecu.
kommon_sense: GOdd idea for using the helms. Now I just need to buy it!
possible air bubble in collant line,
radiator fluid gets routed to the IACV to regulate temp in the TB (or IM depending on what tranny you got ;) )
try flushing it and refilling and make sure to properly do it (aka run car on high heat for several minutes after refill and then check fuild).
right now i have CEL 14 also, but my radiator fluid is clean, and i'm pretty sure i have to clean the IACV ;) (93 octance ownz it)
Discussion Starter #7
interesting.
I had a everely warped head which was dumping alot of oil in my coolant. When I redid the head I added SAMCO high temp hoses and a new Aluminum radiator.
My problem was I didnt have the heater control at the time so I couldnt turn the heater on when I flushed the system.
That was this summer and I have since got the heater control and flushed the system, but I wonder.....
let em know if you get your Code 14 to disappear.
How's your intake manifold gasket?? I went through this same situation with my friends GSR he kept getting intermittent Code 14's we cleand than replaced his IAC and nothing...then I was fiddling around by the head nad I felt something and sure enought a piece of his gasket had cracked and was leaking...after that, we replaced the gasket and the code was gone.
Discussion Starter #9
gasket is good.
I am getting a new IM and Tbody in the near future and I will be picking the Hondata IM gasket. Another potential problem eliminated.
I swear that by the time I am done with this car nothing will be left untouched!!!!!
Sorry for reviving this almost 4 year old thread, but I am having the same problem. I've searched tons of threads but couldn't find anything.
I have replaced the IACV, there's plenty of coolant, no vacuum leaks, my IM gasket is good.. all with no luck. It's a 96 Hatch with a D16y7, with an EX intake manifold. I used the stock throttle body with the 3 wire IACV. The IACV is functioning properly but I still get the CEL code 14. I haven't considered it being a bad ECU, but I guess it's possible? The CEL just came on one day, it didn't happen after working on the car or anything.
Does anyone have any ideas? Thanks :D :)
1 - 12 of 12 Posts
