1 - 8 of 8 Posts
I recently purchased a 2000 accord ex coupe and now I need some advice on drops . I looked at a couple of websites for full coil-over kits that are fully adjustable but was not successful. I live in Canada so I need to be able to raise the car to stock in the winter but will have the full slam in the summer :D. Any ideas? I plan to put 18" Motegi MR7's but after reading a couple threads I might consider 17's because of rubbing. Any help is appreciated...thanks!
sorry, cant help you with that....just wanted to complement on the choice of rims....im getting the same ones and they kick ass
I've decided to go with 17's and a 215/45/17 tire size. The only thing is the drop. Are coil-overs really worth it and who makes full coil-overs for my car? I was thinking also about Eibach Pro-Kit which have a 1.5" drop so it should settle around 1.75. Any ideas?
Kamozee said:
I looked into both and now I also saw NEX. Between the three, I have a good choice. Does anyone have any personal recommendations, or even actual applications?
nex are definitely the cheapest of the three, and ive heard the ride quality isnt that good. i would go w/ tein, but they are the most expensive. they are the best because you can adjust the ride as well as the height.
Discussion Starter · #8 ·
Between Tein and APEXi, I am assuming that Tein has better ride quality? I'm more concerned with ride quality but I always wanted the benefit of height and dampening adjustability. Thanks a lot for the info!
1 - 8 of 8 Posts
