Colder air is always better. If the turbo adds 30 degrees (example) to the intake charge then 75 + 30 is less than 90 + 30. Anything you can do to keep the intake charge cool helps. Turbos are probably more sensitive to changes in the intake temp than NA motors, as the volume of air is increased so the effects of temperature are increased.
