the main difference between the two is the intake velocity. with the long intake your intake velocities will be higher than the short intake. the actual temperature differences have little bearing on the hp differences. thus the longer your intake, the better your gains will be as long as you minimize the bends and anything else that might slow down the air velocity in the tube.man said:How much difference in horsepower is there between the two? For example, AEM.
I don't think the intake velocity has ANYTHING to do with the power.....intake velocity deals with when you hit the power. People complain about the LAG the CAI system has. that lag is the engine bulding the intake velocity in the long tube......kinda like sucking through a long straw....it takes some time to build some pressure......in a short ram the tube is shorter and has the ability to SUCK quicker and build more pressure quicker, having more power right when its demanded.del_parker said:the main difference between the two is the intake velocity. with the long intake your intake velocities will be higher than the short intake. the actual temperature differences have little bearing on the hp differences. thus the longer your intake, the better your gains will be as long as you minimize the bends and anything else that might slow down the air velocity in the tube.
well, i'm just going off of brady's 187 runs on a dyno that showed the longer pipe consistently making more power... the difference in temperature was a mere 2 degrees...not enough to make an impact on hp figures. btw he wasn't using a cold air intake, he just added a 6 foot pipe onto the intake and noticed a nice gain.lOOkatme said:I don't think the intake velocity has ANYTHING to do with the power.....intake velocity deals with when you hit the power. People complain about the LAG the CAI system has. that lag is the engine bulding the intake velocity in the long tube......kinda like sucking through a long straw....it takes some time to build some pressure......in a short ram the tube is shorter and has the ability to SUCK quicker and build more pressure quicker, having more power right when its demanded.
as for more HP...colder/denser air will benifit the engine more than sucking it in quick for max HP.
as to which one is better...thats totally up to you. short ram intakes are generally louder.
i have had both and i prefer SRI too. it's responsive and heat is no problem for preludes coz the battery is blocking it. as you can see on my sig, it says cai but actually i have sri. i just 4got my pw n cant change my sig. lol my cookies are on that's y i can't be logged off.ssrprelude said:I have had both AEM short ram and CAI. They are both good but I prefer the short ram. It is easier to get to, and sounds great. The heat problem is not an issue on Preludes, because it sits behind the battery. I have felt the filter and the tube after driving on a long trip, and after letting it idle with the hood closed. They stay the same temp. This is just my experience.
i SERIOUSLY doubt that choosing one intake over another makes a 4 car length's of a difference.japspecprelude said:I have a iceman intake on my 4g lude and my friend has one on his 3g ls...we raced wit the short arms in and it was close...when i put the cold air in i beat him by 4+ car lengths at a 80mph roll against his short arm...if i was you i would buy a iceman cold air (best hp purchase).
96si
iceman intake
testpipe.com testpipe
apexi n1 cat back
bm fpr
skunk2 camgears
aem pullies
msd 6aL
i used to say that it wouldnt get hot in a prelude b/c it was behind the battery on other boards and like everyone would disagree...ssrprelude said:Like I said, I have tried them both and prefer the short ram, it is easy to clean, and does not get hot at all on my 2000 Prelude. The filter area that sucks in the air stays very cool. It should not get hot on any Prelude because is sits behind the battery. They will both work of course, so go with want you want.
i have an injen SRI on my ride with the injen heat shield, so that helps alleviate this whole 'heat' issue somewhat i guess. i'm happy with it.crdcz03 said:i used to say that it wouldnt get hot in a prelude b/c it was behind the battery on other boards and like everyone would disagree...
im gettin ingen short ram. anyone heard anything bad about ingen?
