i searched this and couldn't find anything on what the compression for an h22 should be. i am putting out what seems to me an excessive amount of black smoke through vtec. i know that smoking through vtec is normal but like i said seems excessive. no oil resin on my bumper so i'm sure its nothing critical yet. i have 1 cylendar at 190 and 3 at 195 is this good and at what time should i rebuild or atleast re-ring it?
those seem like decent numbers to me, the main thing you want to watch for is extreme variances from cylinder to cylinder
from my experience, the most common causes of losing that much oil would either be worn piston rings or worn valve guides.
there's a greater chance of worn rings though, so I'd look there first. compression/leak down testing on all cylinders will tell you.
the H22A, I'd say anywhere from 190-210 is about average for most of 'em... and like TheRedPill said earlier, a 10% difference between cylinders is generally considered 'industry standard'.
it is fairly normal to burn a good bit of oil when using VTEC regularly. I wouldn't worry about it much until using VTEC causes you to burn insane amounts of oil... where you're putting a quart in it every week. I know a couple high mileage 'Luders that have to do this (like 5th gens, 140K+ on the odo). There's lots of Preludes that'll get that black soot all over the rear bumper... and it's almost always this burnt oil residue that we're talking about now.
