1 - 8 of 8 Posts
I don't believe other filters will fit in Comptech's box. You need the Comptech filter, if I'm not mistaken. I suppose you could *make* a filter fit.
The difference between using Comptech's tube and the OEM tube is basically nothing.
So where are you gaining the power from? Is it the foam filter? I took out resonator and I have the piping right behind the turn signal and also the have the K&N drop in, will buying the comptech ice box make much of difference?
No.
1 - 8 of 8 Posts
