What's the cheapest way to read the codes from my engine? The shops want $60 to $80 for a diagnosis.
flyingtoaster said:I went to Autozone yesterday and asked if they would do that for me. They said they no longer read the diagnostics, but they loan you the machine for $180 :eek . That didn't sound right, so today, I called another location and heard the same thing.
Yeah, they usually don't even fully run your card. They do a carbon copy and then if you break it, they charge your card. The tool will tell you exactly which codes it throwing, then you just look them up. Super easy!spray004 said:Hmm that sucks, well they do have a loaner tool program. Basically you pay for the tool, use it, and return it for a full refund. Overall it just costs your time and gas to go to the store.
GSRGreenSleeper said:Yeah, they usually don't even fully run your card. They do a carbon copy and then if you break it, they charge your card. The tool will tell you exactly which codes it throwing, then you just look them up. Super easy!
Those things are kinda pricey. I know people at shops so they hook me up. It helps working in garages from time to time....hobie237 said:thats awesome, but i prefer to buy the tool, since i constantly need to read codes...
i really hate those old style codes u get by jumping the connector.its ok for obd1 cars but for obd2 i prefer using obd2 codes. i have a snap on and OTC scantool at work i use and man the info u get out of it is amazing. thats why i love obd2 for diagnostic reasons. they get straight to the point with the codes. no more of codes like 7 TPS or 10 IAT. they are way more specific.Snoopy said:pull the codes yourself
http://www.c-speedracing.com/faq/06.php
http://www.c-speedracing.com/faq/05.php
theres no such thing as a POS scanner for 125 bucks.2slow2go said:buy a POS scanner off of EBAY. works great for 125 bucks and its yours 4ever
asianpride559 said:theres no such thing as a POS scanner for 125 bucks.
do u even knoe wats a scanner and wats a POS code reader?
i see u dont. :rolleyes
but if u do see a scanner for 125 let me knoe ill pay 300 for it
it reads data from the computer and you can do specific tests on it such as shutting ijectors off, playing with IAC, and clicking relays on and off. its called functional tests.explosivpotato said:correct me if im wrong, but a scanner gives you info on the engine's running stats - fuel/air ratio, rpms, engine loading, and some even act as an ecu that takes over for the car's ecu while it's plugged in.
great stuff, especially for tuning.
a code reader just pulls the code numbers off of the ecu and spits em back at you, and if you're lucky it will give you the part the code referrs to.
correct?
