what changes how fast your computer gets into windows desktop? m noticing im not moving into windows as fast as i used to.
what changes could i do to improve that?
seems a bit better once i defrag but still not like before.SuperAkuma said:Are you talking about boot time? It is mainly the hard drive. You can run a RAID 0 setup or get a raptor hard drive.
Other things that slow down the boot time are programs that you installed into windows. A bunch of them are junk programs or programs that you dont really need to boot up. They just load just in case you might need them. And when you do need then, you save like a sec or so from loading them up since they are already loaded. Programs like windows media player, winamp, AIM, photoshop, quicktime, MSN, dvd player program, nero..etc.. Pretty much almost everything that you install into your computer will "want" to load up right when windows start weater you need them or not.
Go to Start > RUN > Type "msconfig" (without the " ") > OK > go to the "Startup" tab. Everything checked are programs that will boot up when your computer start.
Uncheck any that you know FOR SURE you dont need, then click Apply then OK. It will ask you to reboot the computer.
Once you reboot your computer, check that box that pop up to "ok" what you just did. If you dont check the box and just click OK then you didnt do the change.
***Some programs are kinda hard to know what they are. If you dont know what that program is, google the name and it will tell you. After you google it and still dont know, dont check it and ask one of use.***
Also it wouldnt hurt to defrag your computer.
yea i undid a few that i know...and its better after defrag too5gencivic said:did you check msconfig? You probably have approximately 10 to 15 items in your startup section. Disable everything and try a reboot like Superakuma suggested. It should be much faster.
aim, yahoom, ms office,MarriedWithKid said:i hey guys, i did the MSCONFIG thing & want ya'lls help on what i can uncheck
EngUtil
DrgtoDsc
RxMon
QOELoader
CAVTray - belongs to anit-virus
CAVRid - same
PPActiveDetection - popup blocker
jusched
realsched
SOUNDMAN
ca - also anti-virus
qttask
MSMSGS
aim
YahooM~1
MS Office
