Hey guys have a really simple question, but cant figure it out...
When connecting 2 DVC subs together to get a 2ohm load, you connect all the positives together and all the negatives together...
Now does that mean that i run two cables from the back of the positive termina-l on the enclose to a positive post on one of the DVC, and the other cable to the other positive post on the other DVC. Then do i connect the two positive posts on each VC to each other
if each sub dual 4ohm, then you'll get 1ohm when you wire them in parallel. if you have dual 2ohm wired in parallel, you'll get .5ohm. if you have dual 8ohm wired in parallel, then you'll have a load of 2ohm.
So, you still haven't told us whether the subs are dual 2-ohm, dual 4-ohm, dual 6-ohm, or dual 8-ohm. You can get a net 2-ohm load if you have (2) dual 2-ohm or (2) dual 8-ohm.
With (2) dual 4-ohm subs, and without using any modified-transformer set-up, you are only going to be able to configure a 1-ohm, 4-ohm, or 16-ohm load. You could, theoretically, configure a 1.6-ohm or a 10-ohm load (unadviseable as one sub would be louder than the other).
Honda and Acura Car Forums
